Fuses and relay Mitsubishi Grandis
For the Mitsubishi Grandis (NA) 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 model year.
Fuse box in passenger compartment.
fuse box location.
The fuse block in the passenger compartment is located behind the fuse box lid (LHD vehicles) or the personal box (RHD vehicles) in front of the driv-er’s seat at the position shown in the illustration.
fuse box diagram.
legend.
FuseAmpsCircuits protected
110ACapacitor
Ignition coil
27,5AABS control unit
ESP control unit
Centre display
Steering column switches
Combination meter
Engine oil level sensor relay
Body control unit (BCM)
Headlight levelling control unit
Immobiliser control unit
Multifunction display
Optional connector
Airbag control unit
Steering wheel sensor
37,5AAutomatic transmission control relay
Cornering light control unit
Engine control unit
Input shaft speed sensor
Output shaft speed sensor
Passenger's airbag deactivation light
Airbag control unit
47,5ANot used
57,5AAir-conditioning compressor relay
Air-conditioning control unit
Front blower relay
Front control unit
Heated seat(s) relay
Damping control unit
PTC heater relay
Rear blower relay
Rear windscreen defroster relay
67,5ADoor mirrors
730AFront control unit
Windscreen wiper motor
87,5AMass airflow meter
Engine control unit
Fuel pump relays
Vehicle speed sensor
915AAccessory socket
10Not used
117,5ACombination meter
Mirror switch
127,5ACornering light control unit
Sunroof motor
13Not used
1415ABody control unit (BCM)
Rear wiper motor
1515ADiagnostic connector
1610ARear fog light
Rear fog light relay
17Not used
18Not used
1930AFront blower motor
2030AFuse and relay box in passenger compartment, fuse 6
2120ASunroof motor
2220AHeated seat
Heated seat switch
2320ARear blower motor
2410AEngine control unit
R1 Fuel pump relay
R2 Rear blower relay
R3 Fuel pump relay No. 2
R4 Rear fog light relay
R5 Heated seat(s) relay
R6 Power window relay
R7 Front blower relay
R8 Relay, rear demister
R9 PTC heater, relay 2
R10 PTC heater, relay 1
R11 PTC heater, relay 4
R12 PTC heater, relay 3
Fuse box in engine compartment.
fuse box location.
fuse box layout.
legend.
160AFuse and relay box in engine compartment, fuses 27 – 32
Engine control relay
240AFuse and relay box in engine compartment, fuse 26
Condenser fan relay
Radiator fan motor
330AABS control unit
ESP control unit
440AABS control unit
ESP control unit
540AFuse and relay box in passenger compartment, fuse 21
Front control unit
Power window switches
615AFront fog lights
Front fog light relay
715AAccessory socket
810AHorn
Horn relay
920AEngine main relay
1010AAir-conditioning compressor relay
1115AABS control unit
ESP control unit
Engine control unit
Brake light switch
Tail lights
12Not used
1325AStarter relay
1410ABody control unit (BCM)
1520AAutomatic transmission selec
1610AHeadlights
1710AHeadlights
1810ARight headlight
(20A also used)
1910ALeft headlight
(20A also used)
207,5AAshtray illumination
Automatic transmission gear selector illumination
Combination meter
Fog light switch
Glovebox light
Hazard warning light switch
Headlight levelling switch
Heated seat switch
Dimmer
Rear heater
Optional connector
Tail lights
Traction control switch
217,5ANumber plate light
Dimmer
Tail lights
2215AAir-conditioning control unit
Centre display
Combination meter
Front control unit
Multimedia display
Radio
CD player
Optional connector
Vanity mirror(s) illumination
Accessory socket relay
2310AAir-conditioning control unit
Centre display
Body control unit
Radio
CD player
Optional connector
2415AFuel pump relay
Fuel gauge
25Not used
2630ACondenser fan relay
2730AEngine control unit
2810AInlet air control valve (IACV)
Or
Oxygen sensor
2910ACondenser fan relay
Fan control relay
Glow plug relay
Radiator fan relay
Starter relay
3010AExhaust gas cooler solenoid
Swirl control valve
Variable geometry turbine (VGT)
Or
Emission control system
317,5AImmobiliser control unit
3210AHeater blower
R1 Front fog light relay
R2 Horn relay
R3 Not used
R4 Not used
R5 Accessory socket relay
R6 Engine control relay
R7 Fan control relay
R8 Radiator fan relay
R9 Glow plug relay
R10 Condenser fan relay
R11 Starter relay
R12 Air-conditioning compressor relay
Fusible link box in engine compartment.
26120AFuse and relay box in engine compartment, fuses 1 – 15, 22, 24
2750AGlow plug relay
2860AFuse and relay box in passenger compartment, fuse 22
PTC heater
2940AIgnition switch
3080AFuse and relay box in passenger compartment, fuses 15 – 20, 23
31175AFuse box in engine compartment, fusible links 26 – 30, 32
3260APTC heater
nguồn https://fusesdiagram.com/mitsubishi/fuses-and-relay-mitsubishi-grandis.html
